Word Completion
Word Completion
I would like to ask for a new feature in Zeus.
Instead of the project-wide word completion based on ctags, I would like to be able to perform word completion based on words defined in the current document only. The search for possible completions can be dynamic and not based on a database of pre-searched words.
Thanks, Amit
Thanks, Amit
Hi Amit,
There is the WordComplete keyboard function that should already do this. This function is tied to the Edit, Auto Complete Word menu but naturally can also be bound to any keyboard key combination.
If you find a problem with the WordComplete keyboard function, just post a bug report
I encountered with a problem during auto word completion, while having 2 parameters with the same name (same string), but with different case, the auto word complete function return only one option, I would be glad to have the both options, since I am coding verilog HDL, which is a case sensitive language.
I have one more suggestion for the auto word completion function. When the result of the auto word completion function is a single option, make the completion automatically, with popping up the auto word complete options window choice.
Alex
Alex
That should be easy enough to do. Consider it done
So I assume by this you mean the auto complete should use the text from the start of word to the cursor for the completion search or should it use the whole wordPlease enable the operation of the function while the cursor is standing in the middle of the word that required completion
Also how do you see this completing
Is the current word replaced with the completed word selected
The latest Zeus 3.96i patch adds these new features and can be found here:
http://www.zeusedit.com/forum/viewtopic.php?t=1231
