Scripts
amif2000
Scripts
Post by amif2000 »
Just a few questions regarding scripting:
1. Please consider adding TCL/Tk scripting to Zeus (pretty please :)
2. I propose adding a new forum folder entitled "Scripts" for official and user submitted scripts.
3. Can Zeus launch scripts from a directory other than zScripts? We require this for our group to have a central repository of scripts.
Thanks, Amit
Hi Amit,
Because of the way the scripting in Zeus is designed, it turns out that adding a new scripting language is in general quite easy :)
But on the other hand some scripting languages (ie Perl for example) seem almost impossible to embed :(
So all I can say is I will promise to take a look at TCL/Tk and if it turns out to be one of these easy languages I will have a go at adding it to Zeus ;)
That is a great idea. I have add the new "Scripts" folder.
You can configure this via the Zeus.INI file. For more details bring up the Zeus help and use the Index search option to search for the Network Settings topic.
amif2000
Post by amif2000 »
Thanks Jussi for the quick reply
Cool. BTW, the folder is locked :cry:
Works like a charm.
Thanks, Amit
My mistake :oops:
The latest Zeus for Windows 3.96a patch adds TCL scripting to Zeus ;)
Refer to this link for more details: http://www.zeusedit.com/forum/viewtopic.php?t=1035
