Installing Pip for Python
To install pip use the Zeus Tools, DOS Shell menu to open a command line prompt and run the following commands.
1. To start the pip installation run this command:
python.exe -m ensurepip
2. Upgrade pip to the latest version using this command:
python -m pip install --upgrade --force-reinstall --no-cache-dir pip
3. Check the pip installation by running this command:
pip --version
That command should result in the following output:
pip 25.0.1 from ...
