Error while executing the date macro
rbc
Post by rbc »
Hi, executing the zScript\date.zm macro inserts the date in dd/mm/yyyy format but also outputs a line like Day: 0 Month: 0 Year 0 and shows the debug output window with the contents as below.
Unknown Zeus macro function: date
%s Unexpected error running '%s' function.
%s
WARNING: File: "C:\Users\RBC\AppData\Local\Programs\Zeus (x64)\zScript\date.zm" Type: 'Function' Line: 25 Column: 26
Reason: Unknown function 'date'
Macro generated warnings.
Macro script generated '8' Debug, Error and/or Warning message(s).
The actual editing window is populated with the below output, which does contain the date but also the mentioned 0 string.
30/07/2024
Re: Error while executing the date macro
The macros with the .zm file extension are the original Zeus macros that ran using a 'home-grown' scripting engine. The bug you are seeing is some aging of that engine which was long ago relaced by more powerful engines running Python and Lua. This particular error is a date function that appears to no longer exist.
In any case the date.zm macro can be fixed by making the following code changes:
int DateMacro()
  // this macro will only work for document windows so check first
  if (is_document() == 0)
    message("This macro only works for document files!");
    beep();
    return;
  StampDateTime();
  MoveLineEnd();
  Enter();
  Enter();
  string current_date = macro_tag("$DT<d MMMM yyyy>");
  printf("%s\n", current_date);
  Enter();
  string day = macro_tag("$DT<dd>");
  string month = macro_tag("$DT<MM>");
  string year = macro_tag("$DT<yyyy>");
  printf("%s/%s/%s", day, month, year);
  return 1;
That changed macro code will produce this output:
30/07/2024
30 July 2024
30/07/2024
rbc
Post by rbc »
That makes sense, thanks Jussi. To be honest, it's something I stumbled upon by accident so I thought I'd report it but its not like its a big deal. I was on the Execute Script dialog where I happened to enter just date instead of datetime and got surprised by the error.
As an aside, are both the Python and Lua macro engines considered current and fully supported?
Yes they are. Both the Lua and Python engines are updated periodically with the latest Lua and Python releases.
The Zeus Python engine is running the Python 3.11.4 version, and the Zeus Lua engine is running the Lua 5.4.0 version.
Python is currently sitting at version 3.12.4 and Lua is sitting at 5.4.7 so both engines are only few changes behind.
