Problem with auto indent
Jack
Post by Jack »
Hello,
I just upgraded to the newest Zeus from a version about 5 years old. There appears to be a bug in the auto indent algorithm for C/C++ that wasn't present in the older software
If you have this typed in with the cursor in LINE4 under the 's' in struct in line 3
LINE1: void function( void )
LINE2: {
LINE3: struct type_t var[] =
LINE4:
LINE5: }
Then type in an open brace, you now get this
LINE2: {
LINE4: {
LINE5: }
You use to get this with the cursor in LINE4 Immediately after the open brace
LINE2: {
LINE4: {
LINE5: }
Then Hit the enter key, you get this with the cursor in line 5 indented 1 tab more than the braces.
LINE2: {
LINE4: {
LINE5:
LINE6: }
LINE7: }
It is very annoying, I hope you can address it.
Thanks!
Jack
Re: Problem with auto indent
This issue is now fixed in the new Zeus beta versions found here:
32 Bit: https://www.zeusedit.com/z300/zeus-beta32.zip
64 Bit: https://www.zeusedit.com/z300/zeus-beta64.zip
With this new version the behaviour can be control using the Smart Indenting option found in the Templates section of the Document Type.
Turning off the Smart Indenting option will mean this indenting is not performed.
IMPORTANT NOTE: Before installing this new version, make sure you backup your current installation.
Jack
Post by Jack »
I installed the newest Beta and turned off the Auto Brace indenting option. That seems to fix it. Looks like the nwe software introduces a new bug on a different topic. I will start a new thread
Thanks for the help!
