default document types
Re: default document types
I have upload those default document type settings to the following zip file: https://www.zeusedit.com/z300/zeus_default.zip
That zIp file contains default document types settings for both older and newer versions of Zeus.
For a more recent version of Zeus you should use the settings found in the Zeus.Current folder.
For an earlier version of Zeus, including the Zeus Lite version, the settings in the Zeus.Older folder might be a better choice.
These config details need to be copied to the zConfig folder.
For a modern version of Zeus the location of that zConfig folder is found here:
C:\Users\<user id>\AppData\Local\Programs\Zeus\zConfig\
For older versions of Zeus that folder is found here:
C:\Users\<user id>\AppData\Roaming\Xidicone\Zeus\zConfig\
In both case replace <user id> with your user id.
NOTE: Before making any changes I would recommend makign a backup of that zConfig folder.
FYI that 3.97o qualifies as a current version.
