Quote Multiple Lines
This Zeus macro will take a marked region of lines and turn those lines into a single comma separated line.
For example a marked region containing these values:
apples
oranges
lemons
will be converted into this single line of text:
'apple', 'orange', 'lemon'
The source for this script is found below:
--        Name: Qlines
--    Language: Lua Macro
-- Description: This quote lines macro will converts a region of marked
--              lines into a single comma separated line.
--     Example: Running the macro for these three marked lines:
--                  apples
--                  oranges
--                  lemons
--               will become this line:
--                  'apple', 'orange', 'lemon'
    -- macro only works for read / write documents.
    local locked = is_read_only()
        message("This macro only works for writable document files.")
    if is_marked() == 0 then
        message("This macro requires a marked region of lines.")
        return;
    local top    = get_marked_top()
    local bottom = get_marked_bottom()
    local range  = bottom - top + 1;
    if range > 1 then
        -- remove the markings
        MarkHide()
        -- first line of marked region
        set_line_pos(top, 1)
        -- quote the lines
        repeat
            MoveLineHome()
            set_cursor_pos(1)
            print("'")
            MoveLineEnd()
            if range > 1 then
                print("', ")
                print("'")
            MoveLineDown()
            range = range - 1
        until range == 0
        range = bottom - top;
        -- join the lines
        repeat
             LineJoinNext()
             range = range - 1
        until range == 0
        -- position the line and cursor location
