When I use the 'save all files' command/button, no backup files are created. If I save each file individually, then a backup file of the previous version is created.
Zeus 3.98h on Windows 10 Enterprise 64-bit
Grant
Save All files, not producing .bak files for updated files
Re: Save All files, not producing .bak files for updated files
That does look like a bug, which, if confirmed should be fixed in the next release.
One workaround would be to use a script attached to the file save trigger and have the script write the backup.
There is and example of just such a script here: viewtopic.php?f=10&t=6911
PS: There is a new Zeus 3.98i that is available for download: viewtopic.php?f=6&t=7615
I can confirm this is a bug and it will be fixed in the next release.
