Code Folding Fortran
RTT
Post by RTT »
When the IF(...) THEN statement of IF-ELSE-ENDIF block is written on more than one line it cannot be folded.
Re: Code Folding Fortran
Could you try the need xFolder found here: http://www.zeusedit.com/z300/xFolder.zip
RTT
Post by RTT »
Thanks. With this DLL I can fold a multiline IF( )THEN block, but it does not work properly.
Everything up to the end of the file is folded
Could you post the smallest sample of code that shows the folding error :?:
You can format code using the Code but found in the tool bar.
Just hit the Code button and put the sample inside the two tags.
