I'm just starting to setup and use Agent SVN with a new subversion repository, and have it working for the most part, but when I expand a pbl it does a refresh of the source control status and I get a message box for each object in the pbl stating that the object already exists in the local project path. Press OK to overwrite or press Cancel to cancel the operation. I'm not sure why I get this message. How can suppress this message?
Any help is much appreciated
- Brian Prom
P.S. I was going to attach the agent log file, but it says invalid extension when I try to upload it.
Powerbuilder and Agent SVN - Refresh source control status
Re: Powerbuilder and Agent SVN - Refresh source control status
Hi Brian,
This is an issue with PowerBuilder itself.
More details on this can be found here: http://www.zeusedit.com/agent/pb/classic.html
To fix this you need to turn off the Mark files as read only when not checked out Agent SVN option.How can suppress this message?
