SSH Connection is failing...
btallman
Post by btallman »
I have tried to connect to several SFTP servers and I get the same error...
Couldn't agree a client-to-server cipher...
Any thoughts? The server IS defined...
Ben
The FTP logon process should be logged to the debug output window.
Coul you please use the Macro, Debug Output menu to display this output, save it to a file and send it as an attachment to support@zeusedit.com with the title of Zeus SSH Error.
This bug is now fixed :)
To fix this issue you will need to do the following:
  1. Download this file: http://www.zeusedit.com/z300/xnet.zip
  2. Use it to replace the xnet.dll found in the Zeus install directory
  3. Delete this registry key if it exists: HKEY_LOCAL_MACHINE\SOFTWARE\Xidicone\SSH_FTP
  4. Restart Zeus
