window 8 and Zeus
wolivo
window 8 and Zeus
Post by wolivo »
Until recently I have been able to open Zeus as normal on my Window8 machine. Within the last week it will not open. The hour glass spins a few times and then goes away.
I downloaded 3.97s to see if that would solve the problem, but it didn't.
I removed Zeus from my computer and then reinstalled a fresh copy, but it still won't open.
Any suggestions?
So what changed :?:
Any suggestions?
When you start Zeus can you see the zeus.exe in the task manager :?:
Try deleting the Zeus.ini file which should be here:
C:\Users\<user name>\AppData\Roaming\Xidicone\Zeus
Try a full re-install but before running the install rename this Zeus folder:
wolivobus
zeus and windows 8
Post by wolivobus »
I have the same problem. When I install Zeus there are no errors occur. When I try to run Zeusedit, I get an hourglass for a couple of seconds and then nothing.
I have checked all the folders listed in this topic and they are all there. I have tried running as administrator and nothing.
I am not a first time user and have had years of experience with Zeus, but with this version it just is not running. I worked fine after I upgraded from Windows 7 to Windows 8 and then quit working.
I have completely uninstalled the program and all the files and then reinstalled it, but it still did not run.
Does the Program Compatibility Assistant utility report any issues :?:
More debug suggestions can also be found here: http://support.microsoft.com/kb/927386
wolivobus
Post by wolivobus »
I have tried all the compatibility setting with no success.
I have a 32" monitor running @2560x1600 resolution. Would this have any affect on running the program?
I don't see why this would be the case.
Did you change to that monitor and only after that notice Zeus did not work :?:
As I posted in my first reply to this issue, what has changed :?:
If Zeus was running and then stopped running something must have changed.
Was there a Windows update :?:
Was some virus software installed :?:
etc. etc.
The big question is what is it that has changed :?
Also are you too running the Zeus 3.97s version :?:
wolivobus
Post by wolivobus »
Just a quick update. When I updated my Window 8 OS to Windows 8.1, everything works again. Must have been something in one of the windows updates that was causing a problem.
Great to read you are up and running again :)
Thanks for the update. It is much appreciated.
