PowerBuilder - Reverting to prior revision
rdojr
Post by rdojr »
We are evaluating Agent as an SCC provider for PowerBuilder 11.5. Is there a way to revert to an older revision of an object within the IDE? If not, what steps are recommended to do this?
No. The MS-SCCI which is the interface that Agent SVN implements, does not option defined such an option.
I would recommend using the TortoiseSVN utility to do this.
