Lua Language Tutorial
Writing and Running Lua Code
Zeus Lite comes with a version of Lua making it easy to write Lua code.
Zeus Lite can be downloaded from here: https://www.zeusedit.com/lite/index.html
Here is a simple Lua example:
1) Start Zeus Lite
2) Create a c:\temp\test.lua file using the Lua code shown below:
printf = function(s,...)
           return io.write(s:format(...))
printf("Hello from %s on %s\n", _VERSION, os.date())
3) Use the Compiler, Compile menu to syntax check the Lua code.
If the code contains any errors the compiler output window will be displayed showing the errors found in the code.
If the code is correct, a successful compilation message is displayed in the status bar.
4) To run the code use the Macros, Execute 'test.lua' menu and the following output will be captured inside Zeus:
      Zeus Lite - Version 3.98c
      Copyright (c) Xidicone P/L 1993-2025.  All rights reserved.
Hello from Lua 5.4 on Thu Feb 12 16:43:04 2026
Lua Documentation
With any Lua file open, use the Macros, Lua Reference Manual menu to bring up the Lua documentation.
Checking Lua Code for Errors
As mentioned earlier the compilation step checks the Lua code for syntax errors.
For example, consider this piece of code which contains a Lua syntax error:
function Test(value)
    if (value == 0)
This code can be syntax checked using the Zeus Compiler, Compile menu this will result in the following errors:
luac54.exe: C:\temp\test.lua:3: 'then' expected near 'return'
Lua 5.4.6  Copyright (C) 1994-2023 Lua.org, PUC-Rio
