To ues this file:
1) Save the code below to ccobol.cmd to the Zeus folder
2) Use the Options, Document Types menu to edit the COBOL document type.
3) In the compiler section set the command line to be:
ccobol.cmd $fnCode: Select all
line [0-9]+:Code: Select all
@ECHO OFF
@ECHO Batch Compile for Aramis 2000 version 10, ACU 2.3.
@ECHO Compilation results found in %1.err
REM Delete any previous error files
IF EXIST %1.err DEL %1.err
REM
REM Zeus will have set the current directory to that of the file being compiled
REM
REM Setup the COPYPATH for this file (change to suit)
SET COPYPATH=..\fd;..\cpy;\usr\aramis\sources\newfd;\usr\aramis\sources\cpy
REM Run the COBOL compiler (change to suit)
C:\ACUCBL43\ACUGT\bin\ccbl32 -v -Sx ACU4 -C23 -ZD23 -Crsh -Sar -o \u3\aramis\newobj\%1 -e %1.err %1.SRC
ECHO "Compilation Complete. " >> %1.err
REM Send the error file to Zeus
Type %1.err
