- Go Language Autocomplete
- Go Programming Using Zeus
- Go Debugging Using Zeus
- Workspace Build, Run and Intellisense
- Manage Go Builds using the Zeus Workspace
- Manage Go Packages Using the Zeus Workspace
1) Install the Go language using the installer found here: http://code.google.com/p/go/downloads/list
2) Make sure you are running the Zeus Version 3.97j or better, which can be downloaded from here.
3) Create this c:\temp\test.go file shown below:
package main
import "fmt"
func main() {
fmt.Printf("Go, Hello world!\n")
4) Use the Compiler, Compile menu to compile this file.
5) Use the Macros, Run 'test.go' File menu to compile and run the file. This should result in the following output:
Zeus for Windows Programmers Editor - Version 3.97j
Copyright (c) Xidicone P/L 1993-2012. All rights reserved.
Go, Hello world!6) To format the code to Go formatting standards just save the file and it will be automatically formatted. Alternatively, to manually trigger the format use the Macros, Go Format: 'test.go' menu.
Setting up the Language Server
To setup the Go language server follow the instructions found here: https://www.zeusedit.com/lsp/go.html
Autocomplete for Google App Engine
To get the autocomplete to work with the Google App Engine follow the instructions found here: http://www.zeusedit.com/phpBB3/viewtopic.php?f=5&t=7458
