Some Suggestions
Rat
Some Suggestions
Post by Rat »
I have a compiled a list of minor suggestions in no particular order.
1. A selection from the start to the end of a line should include the line's terminating <CR><LF> pair. Currently I have to move the cursor down to the next line to include these. (CodeWright and Brief used to have this suggested behaviour.)
2. Pressing the <KeyPad 5> should move the page horizontally so that its centered on the line holding the cursor. Currently Zeus moves the cursor to the line at the center of the window. (CodeWright and Brief used to have this suggested behaviour.)
3. When I cut and paste some lines, Zeus will indent them to match the line immediately above the inserted text. Since I can see where this may also be a useful feature I propose an option to disable the smart indenting of pasted text. (Unchecking Smart Indenting doesn't seem to do it.)
4. The '/' forward slash character should by default be added as a string delimiter for XML files. This allows a double-click to select a closing tag name.
I checked this behaviour against Windows Notepad and it does not work this way. Personally I think Notepad is correct in this case and CodeWright and Brief are not doing this right.
In any case it is easy enough to just write a macro to provide the required behaviour and then just rebind the copy keyboard combination to use the macro.
For example here is a Lua macro that should provide the functionality you desire:
    local marked   = is_marked()
    if (marked == 1) and (document == 1) then
        -- see if the cursor is at the end of the line
        if (is_cursor_eol() == 1) then
            local MARK_BLOCK = 2
            local mode = get_marked_mode()
            -- look for the Alt+M block marking mode
            if mode == MARK_BLOCK then
                cursor_save()
                -- move cursor right to include line feed in copy that follows
                MoveLineRight()
                -- copy the data to clipboard
                MarkCopyEx()
                cursor_restore()
                --message_box(1, "debug test" .. mode)
    -- leave up to the default action
    MarkCopyEx()
Once again you should be able to rebind the keyboard to do this.
In this case there may well be a keyboard function that already does what you want, so there would be no need to write a macro.
This is the SmartPaste keyboard function. Once again, all you need do is remap that keyboard key.
Just use the Options, Editor Options menu, select the Keyboard section and rebind the keyboard to suit.
Rat
Post by Rat »
I couldn't find a suitable keyboard function, and am struggling with the macro :(
i'm struggling with the macro
Describe (in about 5 lines of detail) how you think the macro should work an I will have a go at writting it for you.
Rat
Post by Rat »
Pressing the <KeyPad 5> should scroll the page vertically so that it is vertically centered on the line containing the caret.
Currently Zeus moves the caret to the line at the center of the window when <KeyPad 5> is pressed.
(CodeWright and Brief used to have the suggested behaviour.)
This sounds like the ScrollLinePageCenter keyboard function.
Rat
Post by Rat »
Brilliant!
Works perfectly...
Thanks Jussi.
