Workspace (Open files) not getting restored
paul3d
Post by paul3d »
I really like the 'workspace' feature
At any given time I have 9+ project going on and I need to switch quickly between these projects (C++ projects, PHP project, VB.NET Project, VB6 Project) - Ok Ok maybe I have too many projects to work on...
I did find a bug - maybe?
If you have a unchanged file open and you try to switch to another workspace - a popup window will prompt to save and if you 'cancel' -
the workspace will only have that window and when exiting workspace now it doesn't remember the other documents that where open -arrrggg
(Not sure if you can change that behavior - just a FYI)
If you select 'save' all works fine
Paul
Hi Paul,
Thanks for the bug report.
If you have a unchanged file open and you try to switch to another workspace....
I think I have also seen this bug. I'll take a look at it and hopefully it will be fixed by the next release ;)
This bug should now be fixed in the latest release:
http://www.zeusedit.com/zforum/viewforum.php?f=6
