Code folding for the Winbatch (WIL) Language
kevin.bell62
Post by kevin.bell62 »
Hello!
Hopefully I am posting this in the right place. I am requesting code folding for the Winbatch (Windows Interface Language). The info is as below:
Extensions: .wbt, .web, .wil, .wdl
Line Comment: ;
Block Comment: none
Begin: if
End: endif
Begin: switch
End: endswitch
Begin: gosub
End: return
Begin: for
End: next
Begin: while
End: endwhile
Begin: #definefunction
End: #endfunction
Begin: #definesubroutine
End: #endsubroutine
Begin: foreach
End: next
Sample Code:
if x==y then
_do_true_stuff
_do_false_stuff
endif
; "select" may be used interchangably with "switch"
switch (integer_value)
case 1
case 2
_do_for_one ; will process both 1 and 2 condition
break
case 3
_do_for_two ; will process if integer_value = 3
break
case (integer_value)
_fall_through_processing
break
endswitch
gosub _a_subroutine
:_a_subroutine ; subroutines start with the ':' character
_sub_routine_code
return ; returns processing back to line after gosub call
for x = 0 to 100
_do_something_here
break ;; this would exit the loop early
continue ;; this causes the loop to start over at next iteration
next
while (@true)
_do_something_here
continue ;; this causes the loop to start over with condition re-test
endwhile
result = _test_function(3)
#definefunction _test_function(_an_integer)
_a_value_defined = 1 ;; this is local to function
_an_integer = _an_integer + 1
return _an_integer
#endfunction
result = _test_sub(3)
#definesubroutine _test_sub(_an_integer)
_a_value_defined = 1 ;; this is global to entire program
return _an_integer
#endsubroutine
foreach objPrinter in colInstalledPrinters
sPrinterInfo = strcat(sPrinterInfo, "Name: ", objPrinterName, @crlf)
next
Thanks a lot! KDB
This is definitely the correct place to post this code folding request ;)
The WinBatch code folding changes have been made and the new xFolder.dll can be found here:
To install this new dll backup the current dll and replace it with the one contained in the zip file.
To complete the install you will need to create a WinBatch document type and enable the code folding option.
If you find any problems with the folding, just post a bug report to the end of this thread.
kevin.bell62
Thank you Jussi!
Seems to be working great. The only problem I can see is that I forgot to mention that "if" statements can be 1 liners:
if x == y then goto spork
with no "endif". I don't know how you would trap that one anyway, so my thanks yet again!
I have been using Zeus for my Ruby scripts and will now use it for my winbatch scripting as well.
Thanks for a fine product! KDB
A new xFolder.zip file has just been uploaded and it should fix the problem with these one line if statements.
