Code Folding for Foxpro
Hi! this is for a Foxpro prg.
  Extensions: .prg
Line Comment: *
Block Comment: N/A
For begin/end, stuff inside [brackets] are, except for CASE,
optional but would be nice if they could be folded too :)
       Begin: IF
         End: [ELSE]         (Optional)
         End: ENDIF
       Begin: DO CASE
    Alt. Beg:   [CASE]       (Required)
    Alt. Beg:   [OTHERWISE]  (Optional)
         End: ENDCASE
       Begin: DO WHILE
         End: ENDDO
DO is also another keyword separate from the DO CASE and the
DO WHILE.  It is used for calling another prg, procedure, or
function so don't fold on it.  Example:
DO SomeOtherPRG
This would run SomeOtherPRG.PRG and continue on.  You wouldn't
want to fold on this since there is no ending keyword.
       Begin: SCAN
         End: ENDSCAN
       Begin: FOR
         End: ENDFOR
       Begin: DEFINE CLASS
         End: ENDDEFINE
       Begin: WITH
         End: ENDWITH
WITH can also be used with other keywords, but will not start
out the line this way.  When the line starts out with WITH
then it will be the one you want to fold.
       Begin: FUNCTION
         End: ENDFUNC
    Alt. End: RETURN
I don't use the ENDFUNC, but rather the RETURN since I'm
returning a value.
       Begin: PROCEDURE
         End: ENDPROC
    Alt. End: RETURN
I end most of my procedures with a RETURN instead of using
the ENDPROC.  I don't return anything, but it's kind of a
bad habit from using the FUNCTION :(   so you could end
with either a RETURN or ENDPROC.  They do the same thing.
Also, you can have a comment on the same line as code.
(A && will do this)  Example can be found below in the
IF/ENDIF block.
 Sample Code:
IF nValue = 1  && This comment is ignored by the compiler
 * Some comments...
[ELSE]
 ** more comments...
ENDIF
DO CASE
 CASE nValue = 1
   *** Some code would go here, blah blah
 CASE nValue = 2
   *  indenting is not required like in python
 OTHERWISE
   ** optional and used if nvalue = something
   ** other than 1 or 2
ENDCASE
bError = .F.
DO WHILE bError <> .T.
 bError = .T.
ENDDO
SCAN
 ** used for looping through a table
ENDSCAN
FOR i = 1 to 10
 ? i
ENDFOR
frmMyForm = CREATEOBJECT("FormChild")
DEFINE CLASS FormChild AS FORM
 Height = 295
 Width = 524
ENDDEFINE
WITH oApp.oProgBar
 .width = 60
ENDWITH
FUNCTION AddNumbers
 LPARAMERS tNum1,tNum2
 nReturn = tNum1 + tNum2
RETURN nReturn
That's how I use it, but this is also ok.
FUNCTION AddNumbers
 RETURN nReturn
ENDFUNC
My preference would be to fold on RETURN since
a function returns a value.  But if a ENDFUNC
appears before a RETURN, end folding on the
ENDFUNC.
PROCEDURE ProcedureName
 x = 1
 ? x
RETURN
PROCEDURE ProcedureName2
 x = 2
 ? x
ENDPROC
PROCEDURE ProcedureName3
 x = 3
 RETURN x
ENDPROC
These are all correct.  I would recommend folding
on either RETURN or ENDPROC, whichever come first.
The code folding for Foxpro has been implemented and the new xFolder.dll can be found here:
To install this new dll backup the current dll and replace it with the one contained in the zip file.
To complete the install you will need to create a Foxpro document type and enable the code folding option.
jlanquist
You are my hero!
Post by jlanquist »
Thanks a bunch! Instead of adding the new visual foxpro doc type, I edited the Clipper Doc Type and changed the Description to "VFP Document Type" so it now shows as that. Thanks again for your work :D
