Perl Debugger
Perl Debugger
Post by Guest »
Are there any instructions for debugging with perl from within Zeus?
There is a tutorial located here:
Windows Start Button, Programs, Zeus for Windows, Tutorials, Perl Debugger.
Note: The Zeus debugger is just a wrapper around the Perl gdb debugger and is fairly limited it what it does.
Also, you will need to have the Perl gdb installed on your system and the installation directory defined in the PATH envirnonment variable.
