problem with keywords pattern matching
gwgs
Post by gwgs »
2 things:
1. Here's the scenario:
I have a pattern set up on one of the keyword patterns of aptd0???
I have some text:
begin
   somecode
if I type aptd0 or APTD0 at the beginning of any word in that example, Zeus will lock up with 100% cpu usage at the moment that 0 is pressed. The 0 doesn't show on the screen see result as below
begin
   APTDsomecode
Only way out is to crash out and loose any changes made up to that point.
I tried selecting the option pattern matching has low precedence, but with is on or off it made no difference.
2. I tried changing the pattern from APTD0??? to APTD\d{3,3} or APTD0... or APTD0\d\d\d none of these patterns work, the pattern isn't found, yet as a find string it will. (trying to find APTD0??? as a pattern in a find box doesn't find anything)
I am using v4.96q on XP
Grant
I will take a look at this.
The pattern matching was changed for this release so I suspect this change might have introduced this bug :(
Cheer Jussi
I can confirm that this is a bug and it will get fixed in the next Zeus patch.
In the mean time this pattern regexp should work as a replacement:
!(APTD0).{3,3}
NOTE: The ! identifies the pattern as a regexp and (APTD0).{3,3} is the actual regexp.
The bug raised in this thread is now be fixed in the latest Zeus patch found here: http://www.zeusedit.com/forum/viewtopic.php?p=4119
