up arrow key inserts lines
omer kircher
Post by omer kircher »
recently, zeus sometimes gets into a state in which pressing the up arrow key seems to overlay a line. once it gets into this state it continues to do it. i don't know how to stop it.
if i terminate zeus and re-edit the same file, it continues to do it, however it apparently isn't recognized as a change because if i terminate again, i don't get the "do you want to save the changes" dialog box.
i don't know if this is a bug, or if i am accidentally doing something to cause this.
the active keymap is BriefEx.
it is very confusing.
Hi Omer,
I think I now know the bug you are referring to.
The Zeus windows are all highly optimised for painting to reduce flicker so for example, this means if you scroll any window by one line, most of the window is painted with a single bitblt with only the one new line getting redrawn.
This works fine nearly all the time, but on rare occasions when the document is just less or just over one page in length, the painting can get confused (i.e something goes wrong when the scroller and cursor hit the bottom of the page and they somehow get out of wack).
When it goes out of wack, using the keyboard to move the cursor up and down the document shows the painting to be out by one line (i.e. most of the screen painting is out by one line, but as the cursor is moved and the current line gets repainted, it is painted correctly, while the sorounding line are still out by one).
I have seen this bug a dozen or so times, but it is very hard to replicate because it depends on things like the file size, the scroller page length and position, the current font size, the window size etc etc.
The good news is I am hoping it will be fixed in the next patch :)
JackR
Post by JackR »
Hello,
My workaround for this bug is to maximize the window, then restore it.
Jack
