I'm interested in using Zeus editor in emacs mode. I use the ctrl-k and ctrl-y all the time to remove lines and paste elsewhere. It seems as though this feature doesn't quite exist in the emacs emulation. Under gnu emacs ctrl-k will kill the contents of the line, and another ctrl-k will delete the blank line left from the previous ctrl-k. crtl-y behaves a bit weird as well.
Am I doing something wrong? This feature alone will dictate my purchase. I use Linux/emacs a bit and have to be able to have this feature working the same as Linux.
thanks and regards,
gh
emacs line kill and paste
greenhobby
Based on your description of the required Emacs functionalitty I think the following emacs_cut.lua macro will do something similar:Under gnu emacs ctrl-k will kill the contents of the line, and another ctrl-k will delete the blank line left from the previous ctrl-k.
local locked = is_read_only()
-- can't run astyle.exe on current document
message("This macro can only be run with a named, writable document file.")
-- disable screen updates
-- get a copy of the current line
local text = get_line_text()
-- see if the current line is empty
if string.len(text) == 0 then
-- delete the current line
LineDelete()
-- save the current cursor
cursor_save()
-- add the text to the clipboard
set_clipboard_text(text)
-- replae the line with an empty line
LineDelete()
MoveLineHome()
EnterOpen()
-- restore original cursor
cursor_restore()
-- restore screen updates
key_macro() -- run the macroIt should be possible to right a similar Lua macro to implement the required clipboard paste functionality.crtl-y behaves a bit weird as well.
