Perl plx File Extension
Post by Guest »
Nihal Titan wrote:
I just have one problem, I've added an extra extension to my perl document types 'plx', and for some reason the collapse icons '-' don't appear on any of these documents. Is there something else I need to do to get these to show up, or have I found a bug?
The xFolder.dll will be changed to handle this file extension and a new dll posted shortly.
The code folding for the Perl plx file extension has been implemented and the new xFolder.dll can be found here:
http://www.zeusedit.com/z300/xfolder.zip
To install the new dll make a backup copy of the current xFolder.dll file located in the Zeus installation directory and replace it with one from the zip file above.
To get plx files to fold make sure the plx extension is added to the Perl document type.
ntitan
Post by ntitan »
Thank you!
