C# Language Tutorial
To use Zeus to compile and run C# programs you first need to make sure the C# compiler (i.e. csc.exe) is installed and in the system path.
One way to get the C# compiler is to install the .NET SDK found here: https://www.microsoft.com/en-us/downloa ... x?id=53321
Use Zeus to write the C# code and then use the Zeus Compiler, Compile menu to compile that code to produce and executable.
Then use the Macros, Execute menu to run the resulting executable.
As an example create the test.cs file shown below:
class Test
    static void Main()
        Console.WriteLine("Hello World!");
Compiling this code should result in the following compiler output:
Microsoft (R) Visual C# 2005 Compiler version 8.00.50727.42
for Microsoft (R) Windows (R) 2005 Framework version 2.0.50727
Copyright (C) Microsoft Corporation 2001-2005. All rights reserved.
test.cs(5,9): error CS0103: The name 'Console' does not exist in the current context
The error can be fixed by adding the using System line of code shown below:
using System;
class Test
    static void Main()
By recompiling the code this time a test.exe will being created ;)
Now run that executable using the Macros, Execute menu and the output will be captured inside Zeus.
Note: The latest version of Zeus can directly import and build Visual Studion solution files so this tip is now obsolete, but it remains as an alternative option ;)
Additional Information:
Using Zeus with C# .Net Core
Using Zeus with Microsoft Tools
Working with the C# 2.0 Command Line Compiler
