Very useful feature.
Please include *.wsf with the same settings as *.vbs
WSF
A new xFolder.dll can be found here: http://www.zeusedit.com/z300/xfolder.zip
Make a backup copy of the current xFolder.dll file, located in the Zeus installation directory and replace it with this new dll.
You will also need to add the asp and wsf file extensions to the Basic Document Type, or alternatively create a new Document Type and enable the Display line folds margin option.
If you find any problems with this new dll just post a reply to this topic.
