I am now evaluating the program and I like it very much.
I have found a problem in the folding that does not let me use it in FORTRAN in many files. In FORTRAN you can use a single line IF without THEN and ENDIF. Something like: IF ( ERROR ) EXIT . This confuses the folding. You should ignore IF's without THEN in the same line.
Folding in FORTRAN for IF without THEN
Hi Dmaon,
To install this new dll backup the current dll and replace it with the one contained in the zip file.
If you find any other issues or have any other suggestions regarding the Fortran folding feature feel free to post them to this forum.
This Fortran code folding change has been made and the new xFolder.dll can be found here:You should ignore IF's without THEN in the same line.
