Code folding and text selections
aphor
Post by aphor » Sun Dec 22, 2013 12:07 am
I'm not sure if this should be here or under the bugs topic. Feel free to relocate this if I chose wrong...
I found a problem with my SlideIn/Out scripts that also appears to affect Add/Remove Comments. comment_range() appears to work on display line, not file line:
For example, if I have
public class Bob
    bool SomeFunction()
        return(true);
    bool AnotherFunction()
        return(true);
and fold SomeFunction() so AnotherFunction begins on display line 6 like so:
public class Bob
    bool SomeFunction()
        return(true);
then select the text of the entire AnotherFunction() and execute Macros->Add/Remove Comments, the resulting text is:
public class Bob
    bool SomeFunction()
        return(true);
    // bool AnotherFunction()
        return(true);
I initially thought this was going to be related to get_marked_top() and get_marked_bottom(), but I when I put together the simplest test I could think of:
    message
        string.format
            "Selected range [%d:%d]. Current line: %d",
            get_marked_top(),
            get_line_pos()
It correctly displays the selected line numbers regardless of fold state. If I include the folded text in the selection (i.e. same fold as above, but attempt to comment out both methods), commenting works correctly.
I've run out of time to look at this today, but thought I'd post here in case you have an immediate idea where the problem is.
Thanks!
aphor
Post by aphor » Sun Dec 22, 2013 1:03 am
Okay, so I can't walk away from an unresolved problem...
I believe set_line_pos() is the culprit here.
    local lineToSet = get_marked_top()
    set_line_pos(lineToSet)
    message
        string.format
            get_marked_top(),
            get_line_pos()
run against the example folded example code with "AnotherFunction()" as the selected text will show:
Selected range [8:8] Current line: 6
A simple loop around set_line_pos() to make corrections should solve my problem (that really will wait until later), but having set_line_pos() behave as expected would be even better. :)
Post by jussij » Sun Dec 22, 2013 1:08 am
That does indeed look like the problem.
Using your test file this simple macro adds the string to the wrong line !!!
    -- should add the string to this line of the test file
    -- bool AnotherFunction()
    set_line_pos(8)
    MoveLineHome()
    print("Start of line: ")
I will look to get that fixed ASAP.
Thanks for submitting the bug report :)
aphor
Post by aphor » Sun Dec 22, 2013 7:50 am
Thanks!
Post by jussij » Sun Dec 29, 2013 1:10 pm
This folding issue should be fixed in the beta version found here: http://www.zeusedit.com/z300/ze397r-beta.zip
To use the files in this zip file just make a backup copy of the Zeus install folder and replace the files contained in that folder with the ones in the zip file.
aphor
Post by aphor » Thu Jan 02, 2014 9:46 pm
Your test macro
    set_line_pos(8)
    MoveLineHome()
works correctly with the change, but "Add/Remove Comments" and my Slide In/Out scripts still behave incorrectly. (Same behavior as decsribed above).
A bit of investigation makes me believe the problem is either in comment_range() or comment_line() [if I just call "print" in my script, it works as expected], but I don't see an obvious cause. I'll look at it more tonight.
Thanks!
Post by jussij » Fri Jan 03, 2014 12:34 pm
Thanks for the feedback :)
The problem was with the set_cursor_pos macro function in that just like the set_line_pos macro function it was not accounting for handling the folded lines.
The new beta version from the link below should fix this issue: http://www.zeusedit.com/z300/ze397r-beta.zip
aphor
Post by aphor » Fri Jan 03, 2014 8:36 pm
Confirmed fixed. Thanks!
Users browsing this forum: No registered users and 13 guests
