find next function
JackR
find next function
Post by JackR » Fri Mar 15, 2013 6:38 pm
The feature to find the next function ( control-down_arrow or control-up_arrow ) is no longer working correctly in C++ files. I'm not sure when it stopped working. It stops at many lines that aren't functions. I believe the problem is that it is stopping at any line which contains a double colon (::). I have a lot on lines in my code that have this structure
class_name::enum_constant_declared_in_class
This needs to be distinguished from a function which looks like this:
void class_name :: function_name( parameters)
Hopefully, this can be fixed because I use to love this feature.
Thanks!
Jack
Post by jussij » Sat Mar 16, 2013 3:13 am
In the general section of the document type there is a function regexp that defines what is a function.
All you need to do is create a regexp that defines the lines that are functions.
For example this regexp
[a-zA-Z0-9_]+::[a-zA-Z0-9_]+\(
will identify lines of code like the following as functions
void class_name::function_name( parameters)
To add more definitions just use the regep or construct:
([a-zA-Z0-9_]+::[a-zA-Z0-9_]+\()|(some other regexp search)
JackR
Post by JackR » Mon Mar 18, 2013 3:08 pm
Thanks for the feedback, I didn't realize I could configure this. But unfortunately, this just changes the problem. I didn't do a complete job of asking my question. I want to find function definitions for C and C++ of the form
return_type class_name :: function name ( parameters )
return_type class_name :: function name ( parameters,
return_type function name ( parameters )
and not find lines which call functions or have similar structures
function( parameter );
function (
if ( result > sizeof(tag) )
class_name::enum_variable
I'm not very good at regular expressions, but I don't see any way to find just the functions.
Thanks!
Jack
Post by jussij » Mon Mar 18, 2013 10:23 pm
Hi Jack,
Try this one:
^[_a-z0-9]+[ &*\t]+[_a-z0-9 :\t]*[_a-z0-9]+[ \t]*[(]+.*
To test my regular expressions I just use the find dialog in Zeus itself.
In the expression given the ^ represents the start of line, the [...] represent a set of charaters, the + means it must be found, the * means optional and the .* means any characters.
JackR
Post by JackR » Tue Mar 19, 2013 6:57 pm
Thanks for the help. Your solution doesn't fix the problem 100%, but it is so much better and very usable now. It still stops a prototypes of functions which is a very minor issue.
Thanks again!
Jack
Post by jussij » Wed Mar 20, 2013 2:18 am
Just change the regexp to be this:
^[_a-z0-9]+[ &*\t]+[_a-z0-9 :\t]*[_a-z0-9]+[ \t]*[(]+.*[^;]+$
The [^;]+$ addition says ignore any line that ends in a semi-colon.
In fact since functions can be written using upper case letters the regexp should be this:
^[_a-zA-Z0-9]+[ &*\t]+[_a-zA-Z0-9 :\t]*[_a-zA-Z0-9]+[ \t]*[(]+.*[^;]+$
JackR
Post by JackR » Mon Mar 25, 2013 2:27 pm
Thanks so much for your help. You may want to consider making this last reg ex string you provided me the C/C++ default when none is provided.
Thanks Again!
Jack
Users browsing this forum: No registered users and 3 guests
