ftp file naming in version f
bsuggo
Post by bsuggo » Fri Jun 10, 2011 2:00 am
just downloaded 3.97f
in previous version(3.97e) when you downloaded an ftp file the name of the file was displayed on the tab. In version f the file name is displayed as something like "ftp8CC8.tmp". should be eg "rebreport.spl"
As the file extension is changed nothing works as it used to. :(
pc is running windows 7 professional 32 bit
when upgrading I renamed old folders and then copied
C:\Users\xxxxxxxx\AppData\Roaming\Xidicone\Zeus back in
I'm confused :o
Post by jussij » Fri Jun 10, 2011 2:05 am
This looks like a bug introduced into the 3.97f version :(
Thanks for the bug report.
Post by jussij » Tue Jun 14, 2011 1:46 am
A new beta release has been created that should fix this FTP issue.
This beta can be found here:
http://www.zeusedit.com/z300/ze397g-beta.zip
Users browsing this forum: No registered users and 17 guests
