Pseudo Off Topic Question about perforce.
Xarzu
Post by Xarzu » Mon Sep 29, 2008 5:14 pm
I am using Perforce on the command line and I have a question.
I have been asked to "revert" a change that I made
I figure that that is no problem. I go to a command line interface and I log into perforce. Then I type:
p4 revert "the version number" "the filename with path"
Of course I gave it the actual version number to revert and the actual filename with path.
It gave me two errors:
"the version number" - file(s) not opened on this client.
"the filename with path" - file(s) not opened on this client.
Post by jussij » Mon Sep 29, 2008 11:33 pm
What little I know of Perforce is it will only let the user work with files that are defined in the users client spec.
So I would guess this message suggests to me your client spec is not configured to include the files you are trying to revert :?
But I would a suspect you would also get a better answer if you posted this question on the Perforce forum.
Xarzu
Post by Xarzu » Wed Oct 08, 2008 9:54 pm
Where is that?
Post by jussij » Thu Oct 09, 2008 3:32 am
Where is that?
Here.
