Jussi,
Some time ago, someone requested a facility in Zeus to find references. http://www.zeusedit.com/forum/viewtopic.php?t=739. I've also asked for a Find All features, mostly to find references in the current document. The grep solution works well, and creating a macro to do it helps even more, but it seems to me that this could still be improved.
As you comment in the topic above, it should be possible to integrate an xref tool into Zeus - unfortunately, I haven't found one yet at a price I'm willing to pay (not much). However, for COBOL at least, I think I could put one tegether pretty easily. Another possibility is to use the compiler's XREF output.
Here's what I'd like to see:
Use a database similar to the tags DB to store references as well. The content would be the name and where it's defined, possibly the type of definition. This would be followed by a list of references with where it's used. Having the ability to store a reference "type" would also be very useful - could be used for referenced, tested, modified, etc. - any type of usage that makes sense and can be derived by a tool.
Use a function similar to "show definition" to show references - bring up a list of references the same way "go to definition" does with tags - if there's only 1, just go there. Obviously, you could go to any item on the list. The only significant difference would be to display the reference type also.
I think you told me in a different conversation that the tags database has a reference type that wasn't used currently. If you had a way to populate them, could this be used to do the job? If the tag process could be extended (externally) to also provide reference data, that would provide a very useful capability.
A side note - to an old mainframe programmer, the tags facility is just awesome. However, after using it a while, I find myself wishing for a "Back" button like in a browser. If I remember properly, Brief used to provide something like this with a push/pop cursor command, but I haven't seen this is Zeus. In any event, it'd be very nice to have it automated to come back from definitions, references, finds, etc.
References
Hi Bill,
Do you have an example of the compiler's XREF output
The difficulty is not so much in creating the database, but more in defining the source of the XREF data.
If the ctags.exe provides a XREF option then this might be one possibility
While this would require a fair amount of code to be added to Zeus to manage, display and navigatie this reference information, it should definitely be possible
This is critical part. As Zeus will have to parse this XREF information there needs to be some sort of standard XREF data format.
Since Zeus can currently parse the ctags format it would be best if this XREF information is also in ctags format.
http://www.zeusedit.com/forum/viewtopic ... wnextfocus
Alternatively there are also the TagsSearchRedo, TagsSearchUndo keyboard functions
This is the solution I would also recommend. It should be easy enough the search the compiler XREF output using a grep tool and have the results displayed in Zeus.Another possibility is to use the compiler's XREF output.
You might be able to use these Zeus keyboard functions WindowNextFocus, WindowPreviousFocus which are described here:However, after using it a while, I find myself wishing for a "Back" button like in a browser.
References
Jussi,
I'll check out the keyboard functions you mentioned - I've used the WindowPreviousFocus (I assume) - it works well when the tag is defined in a different file, not so well when in the same file. Another issue is that it would be nice to have a stack of "back" points. I haven't had a chance to check out the TagSearchUndo function yet.
What I had in mind for references was to provide a reference file in ctags format. That would eliminate your needing to parse a new file format. This seemed relatively easy until I looked at the compiler output a little more. The XREF consists of the listing line number where a symbol is defined, with reference listing line numbers following. The problem is that the listing line number bears only a passing relationship to the source file line number. First, this compiler only numbers executable lines - worse, it claims to number statements, where a single line can contain more than 1 statement. Second, it numbers lines from COPY files (files copied in to the program for compilation). This certainly makes the job a bit more complex, since it would obviously be nice to have accurate line numbers that refer to the (or a) source file. I don't think this is an insurmountable obstacle, but it does make life a little more interesting.
How does Zeus locate a tag definition - using the line number or with the tag file pattern field? What does the inherit field do? How about attribute? Are these fields used in the class browser? Since I've been working mostly in COBOL so far, I haven't seen where these might show up yet.
I thought of another useful capability when displaying references - it would be nice to see file (the active document), project (any file in the workspace), or global (any available reference/tag DB) references selectively.
I'll keep you posted on my progress in producing an XREF file file when I make any.
Bill
Bill
Hi Bill,
The TagSearchUndo, TagSearchRedo functions hold the "tag points" in a stack so you should be able to move back and forth at will
I think the reference tag item that is currently in Zeus was never actually used, but instead was added just in case
Zeus uses the line number and file name. The pattern is used in things like the function tooltip and class browser display.
The inherit field shows that the class was inherited from some other base class. Zeus will display the class details and the details of it's inherited base class.
The attribute contains the timestamp of the file. Zeus uses this value to check if the file needs to be re-tagged.
The type, name and pattern are the details displayed in the class browser.
The pattern is displayed if the Options, Editor Options, Use class browser long names options is checked.
With a suitable reference source the file and global views would happen automatically
For example, currently all the tag information shown above the Project Files folder represents a global or workspace view while at the Project Files level the tag information is grouped by file.
I looked at the ctags and unfortunately it does not produce XREF informationThis seemed relatively easy until I looked at the compiler output a little more.
TagSearchUndo
Jussi,
In some brief testing of TagSearchUndo, it appears to work if there is only a single definition of the tag in the database. When there are multiple definitions, the list of definitions comes up and allows you to choose. After doing that, TagSearchUndo does not appear to work.
Am I doing something wrong?
Bill
Bill
