Problem starting zeus 3.96n
TonyMc
Post by TonyMc » Wed Feb 27, 2008 10:44 pm
I have just tried installing Zeus 3.96n and I cannot start zeus now. When I try to start (either by typing the name of the executable or by double clicking the desktop icon) I get a dialog box that says:
Unable to execute file
C:\Program Files\Zeus\zeus.exe
CreateProcess failed; code 14001.
This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem
Any suggestions as to what I can try? Thanks.
Tony
Post by jussij » Wed Feb 27, 2008 11:13 pm
Hi Tony,
I would do this:
  1. Rename you current Zeus installation folder to zeus_old
  2. Run the full Zeus installer found here: http://www.zeusedit.com/z300/ze32v396n.zip
Now if this works and Zeus starts correctly, I would stop Zeus and copy over you zeus_old\zConfig folder and again see if Zeus will start.
TonyMc
Post by TonyMc » Wed Feb 27, 2008 11:40 pm
I have just tried that but I am still getting the same dialog box when I try to launch the new version. It's not that important - I kept a copy of the zeus installation directory so I can go back to 3.96m for now. I have checked that 3.96m still works ok.
Tony
Post by jussij » Mon Mar 31, 2008 11:44 pm
Could you please try the latest Zeus version found here: http://www.zeusedit.com/forum/viewtopic.php?t=1790
TonyMc
Post by TonyMc » Tue Apr 01, 2008 1:37 pm
Thanks Jussi, that seems to have fixed the problem.
Tony
Users browsing this forum: No registered users and 8 guests
