Opening file with UTF-8 encoded name from Explorer fails
kleist
Post by kleist »
[Zeus 3.97e / Windows 7 SP1 64 bit]
Trying to open a file with a UTF-8 encoded name (like "räksmörgås.txt") from the Windows Explorer fails. The same if a file with an ascii name resides in a directory with a UTF-8 encoded name.
If the file is simply (double)clicked, nothing happens, i.e. no error message appears.
If I choose "Open with" from the context menu, and then "Programmer's Editor for Windows", the error message "There was a problem sending the command to the program." is displayed in a window.
Opening the file with Notpad or Textpad works fine.
Unfortunately I was not able to replicate this issue :(
But I am running a Win32 bit version of Windows which might be part of the problem.
What I did was start Explorer and used it to create a new file in the temp folder location with this name: räksmörgås.txt
Now from inside Explorer I can drag and drop the file, Open With and I double click on the file and in all cases the file opens just fine in Zeus :?
Could you send me an example file as an e-mail attachement :?:
What is interesting is if I do a dir räksmörgås.txt inside of Zeus I see this:
Directory of C:\temp
30/03/2011  09:56 AM                11 r„ksm”rg†s.txt
But if I run the same command from the command prompt I see the correct name:
Directory of c:\temp
30/03/2011  09:56 AM                11 räksmörgås.txt
I suspect this is due to a bug in the Zeus tool capture output code :(
kleist
Post by kleist »
Hello again Jussi,
I've found something pretty odd...
If I start Zeus, and after that chose "Open with..." / "Programmer's Editor for Windows" from the file's context menu in Explorer, then the file opens fine :!:
Not if I (double)click on the file though.
Drag-and-drop to the Zeus window works fine.
Drag-and-drop to my Zeus shortcut icon on the desktop doesn't work.
This seems to suggest that there is something wrong with the ZeusDocument registry setting :?
In the registry the ZeusDocument is defined here:
HKEY_CLASSES_ROOT\ZeusDocument\shell\open\command
and it should be defined with this default value:
"C:\Program Files\Zeus\zeus.exe" "%1"
What you could try is changing the command line to be:
"C:\Program Files\Zeus\zeus.exe" '%1'
For the file type that fails to load on double click, did you associate the file with Zeus or was it one of the predefined Zeus association :?:
kleist
Post by kleist »
Sorry for not having replied until now, Jussi.
I've verified the registry setting for "HKEY_CLASSES_ROOT\ZeusDocument\shell\open\command".
Changing the double quotes round %1 to single quotes makes no difference.
:shock: When opening the file with an already running Zeus using "Open with... " from the context menu, those single quotes are changed back to double quotes. :shock:
The problem appears both for predefined Zeus associations (like *.txt) and associations made by me (*.acl).
All in all: This is a very minor problem, since Zeus is typically running all the time on my 'puter. And I seldom edit files with non-ascii names.
