Prompted Slide-In/Out Scripts
aphor
Post by aphor » Sat Dec 21, 2013 3:53 am
Macros to replace Prompted Slide-in/Slide-out from CodeWright. comment_range() and uncomment_range() do the heavy lifting, these just set the column and range along with prompting the user for the slide text.
Prompted Slide-in
--        Name: PromptedSlideIn
-- Description: Prefix select block with user provided text
dofile ("AS_NotDoc.LUA")  -- #include file
dofile ("commentText.LUA")  -- #include file
function key_bind()
    -- macro only works for writable documents so do a check
    if (NotDocument() == 1) then
        message("Document is read-only!")
    if (is_marked() == 0)  then
        message("No text selected!")
    local top   = get_marked_top()
    local range = get_marked_bottom() - top + 1
    local col   = get_marked_left()
    -- ask for a user for slide text
    local slideText = user_input("Slide Text:", "")
    -- disable screen updates
    -- save the current cursor
    cursor_save()
    -- move to the fist line of the commented text
    set_line_pos(top)
    -- get the first line of text
    comment_range(range, slideText, nil, col)
    -- restore original cursor
    cursor_restore()
    -- restore screen updates
key_bind() -- run the macro
Prompted Slide-Out
--        Name: PromptedSlideOut
-- Description: Strip user provided text from select block.
function key_bind()
    cursor_save()
    set_line_pos(top)
    uncomment_range(range, slideText, nil, col)
    cursor_restore()
Users browsing this forum: No registered users and 3 guests
