Nested comments
Zoe
Nested comments
Post by Zoe »
I have some code which has nested comments. By this, I mean the following (where block comments are /* */)
/*description*/
code follows here
code follows here
code follows here
code follows here
The way I have it set up at the moment, Zeus thinks that the comment ends at the end of line 2 (after "description") and so all the code following this is not in the format that I've reserved for comments.
So far, all I have done is enter /* in "comment start" and */ in "comment end" under the keyword options tab.
Is this something I just have to live with or is there a way round it?
Can you tell me which which language are you running :?:
The reason I ask is that for C/C++ the comment does in fact end at line 2 in which case Zeus gets it right ;)
Zoe
Post by Zoe »
I use a program called Stata (which is a statistical analysis package) and it's the language used for that.
In this language, the comment defintely ends in the final line :lol:
Not to worry, I can live with it.
Zoe
Post by Zoe »
I have just been discussing this with a C++ programmer and he couldn't understand (at first - I did manage to convice him :lol: ) why I would want to do what I am doing and why I didn't just change the code to:
/*description*/
code follows here
code follows here
code follows here
code follows here
So that you don't think I'm totally dumb :wink: , the code that I actually have is more like this:
/*description of code*/
code
/*more description of code*/
more code
/*even more description of code*/
even more code
And in total there are many lines of code. I only need to temporarily comment out this code (because the program will run without it and it takes a long time) so I don't want to have to comment out each block of code separately.
Stata understands nested comments (thankfully) but I often lose where comments start and end which is why grey text is useful.
It think it should still be possible to add this feature :?
The only reason I asked the question was more out of curiosity and to also make sure I fully understand the issue involved ;)
Zoe
Post by Zoe »
Would be great if this feature was added.
This feature has now been added to Zeus ;)
You can get this feature by downloading the latest Zeus patch found here:
http://www.zeusedit.com/forum/viewtopic.php?t=1000
To enable the feature go to the Keywords section of the Document Type and enable the Nested Comments option.
Zoe
Post by Zoe »
Wow, thanks. That's fantastic.
