reinstalling
thankey
reinstalling
Post by thankey »
How is Zeus deinstalled and then reinstalled on a different workstation?
How do is Zeus deinstalled and then reinstalled on a different workstation?
The Zeus installer adds an uninstall menu option to the Windows Start Button, Programs, Zeus for Windows menu. To deinstall Zeus Just run this menu option ;)
If you wish to maintain any of your current Zeus settings, you should first install the software on the new machine, then copy over the zConfig directory ( found in the Zeus install directory) of the current installation, overwritings the zConfig directory of this new installation.
AlanStewart
Installer
Post by AlanStewart »
What's the consequences of just copying the entire Zeus directory over to the new machine (maybe without the zBackup contents)? Setting up a desktop icon is easy enough to do and there won't be a Start Menu entry (not that I personally care for that). Is there anything else vitally important (registry settings?) that wouldn't be copied over in this case? From what I've been able to tell, Zeus is a hugely robust, self-contained program which makes it very easy to manage.
None ;)
