Smart Indent
AlanStewart
Smart Indent
Post by AlanStewart »
You'll be pleased to know that I've gone all day now without Zeus giving me grief. I dunno what was happening over the past couple days but I figure you gotta be sick of me sending you error dumps by now! :)
Something I've been noticing is that the Smart Indenting seems to have changed from previous incarnations. In the Doc Properties / Template tab, I've got Smart Indenting turned on and Normal Braces selected, but if I've got an open brace at the end of a line and I put the cursor right before it and hit enter to move it down a line, it gets indented instead of going right under the previous line. Now, I'm all for indented braces (it just makes *sense*) but unfortunately the coding standard here at work says that braces line up with the keyword (C++/Java) so it's kinda a pain to have braces being automatically indented. Especially when I'm pretty gosh darned sure that it didn't behave like that in any other version of Zeus that I've used.
Of course, I could be wrong. Just askin', y'know?
Alan Stewart
AlanStewart
Smart Indent?
Or maybe I'm wrong. Maybe it *is* working okay for code but not for function headers?
void
SomeClass::someFunction (int someParameter)
...// Some comment.
Okay, a little bit of experimenting showed that it's indenting to the line *below* instead of the line above. If you take the code above and change it to
SomeClass::someFunction (int someParameter) <cursor>{
and then hit return, you'll get the { indented to match the indentation of the comment. But if the comment isn't there, or there's a blank line right before the comment, then Zeus puts the brace right in column 1, like a good little text editor. Okay. Got that figured out!
Alan
Hi Alan,
The Smart Indenting has been enhanced :)
Get the latest Zeus from here: http://www.zeusedit.com/forum/viewtopic.php?t=975
This latest version has the option to turn on/off the auto brace indenting.
In any case it might also indent you header file example correctly, but if this is not the case, feel free to keep posting examples of where the smart bracing is going wrong ;)
AlanStewart
[quote]Get the latest Zeus from here: http://www.zeusedit.com/forum/viewtopic.php?t=975[/quote]
I've got 3.95y. That's the first thing I check for whenever I have problems. Make sure I've got the latest version!
[quote]This latest version has the option to turn on/off the auto brace indenting. [/quote]
Where is this option? I already have "Normal Braces" set instead of the "Indent Braces" so I'm not sure where to look for other Smart Indenting options.
You will need to get the patch again ;)
As is usually the case the 3.95y version was ready to go and tested for about a week, before being uploaded, the links updates and the announcements made.
Then sure enough two days later I found a similar brace bug to the one you described, so I uploaded a new replacement 3.95y version.
Now I should have released this as a 3.95z release, but since each patch release requires quite a bit of extra work in getting links updated etc, I decided against this and just replaced the existing file.
AlanStewart
[quote]You will need to get the patch again ;)[/quote]
I just got it. And yes, there was an update so that's cool now. Unfortunately it appears that the same bracing issue is there. Oh well, it's not that big of a deal for now. Here's hoping macros are a little more stable now. I'll email you any dumps should things die on me at any time.
So what's the next revision? 3.95aa, 3.96, or 3.96a? :)
This is actually not the smart bracing in action, but rather the smart indenting. All that has happened is the new line has been indented to match the indentation of the next line. What probably should have happened is Zeus should have done smart bracing and positioned the brace to match the indentation of the matching brace :?)
In any case what I would suggest is binding the EnterLine function to something like Ctrl+Enter key and use this key when you need no special indenting. The EnterLine will do a plane an simple enter without the any of the smarts. Naturally to remove the smarts all together you could also bind EnterLine to the Enter key ;)
AlanStewart
[quote]What probably should have happened is Zeus should have done smart bracing and positioned the brace to match the indentation of the matching brace :?)[/quote]
Maybe that would do it. It would just be a matter of finding the closing brace at the end of the function I guess.
Here's another one. Start with this:
...if (sprite = GetSprite ("Sprite"))
......sprite->bActive = false;
Now, just to confuse matters, put the closing brace in *first*, ie. this:
......sprite->bActive = false; }
What I end up with instead, is this:
......sp}rite->bActive = false;
Cool, eh!
AlanStewart
What's the equivalent of
MoveLineHome ()
where it *DOESN'T* do the "smart" indenting? I've been running macros with that in it to put stuff right at the left-hand edge, but if there's an indented line below where I'm working then it all gets indented, which of course isn't what I wanted.
Hi Alan,
What's the equivalent of MoveLineHome () where it *DOESN'T* do the "smart" indenting?
I am not exactly sure what you mean. The MoveLineHome should not do any smart indenting :?
For example, given this very Lua simple macro:
    MoveLineHome()
If I run this macro on any of these lines the cursor moves to the home location:
  this is a test line
     this is a test line
         this is a test line
Have you got a simple macro that illustrates this problem :?:
AlanStewart
- It doesn't, but any \n printed *DO* do the smart indenting.
- Yup!
MoveLineHome()
print ("*\n")
print ("**\n")
print ("***\n")
I guess, really, what I'm whining about , is that I've gotten used to the old smart indent where it basically just indented to the line above (ignoring blank lines) and am having difficulties adjusting to the new one that seems to look to the lines below, or something. I'm used to entering an indented line of code, hitting RETURN a couple of times to get a blank line, then doing another line of code, all at the same indent level. Now, the second time I hit RETURN, the second blank line ends up out-dented and that's not what I what.
Don't you hate traditionalists! :)
You can fix this quite easily. For example the following simple Lua script that will output text without any smart indenting:
function PrintLine(text)
    print(text)
    EnterLine()
    PrintLine("This is line #1")
    PrintLine("This is line #2")
    PrintLine("This is line #3")
AlanStewart
Well, I suppose that's an okay fix. I just wasn't planning on having to edit all my macros to fix the auto indent. I think the fix I'll have to settle for is just making sure that the cursor is right over on the left and that there's a couple blank lines underneath where I want to insert stuff. That should fix things.
Thanks!
AlanStewart
Found another interesting thing. Try typing this into a Java or C++ program:
/// Playing the bet {0-9}NNN.
What happens?
This will be fixed in the next Zeus patch due some time in December ;)
