Wordwrap???
JohnHind
Wordwrap???
Post by JohnHind »
Everything seems to be there for soft word wrap (display only without inserting line terminators in the file) but I cannot make it happen! There's a right margin line and a gutter for the wrap markers, but the lines are still
shown with horizontal scrolling.
Zeus can not do soft word wrapping. It only does hard word wrapping :(
There's a right margin line and a gutter for the wrap markers, but the lines are still shown with horizontal scrolling.
The right margin indicates where the hard word wrap will occur.
If the Line Wrap option found in the document type is checked, Zeus automatically wraps the line as you type past this point.
Alternatively using the Macros, Linewrap Paragraph menu option , you can line wrap the current paragraph and this macro also uses this margin as a guide.
But in both cases the wrapping is hard (ie Zeus inserts a CR/LF).
williamrouse
line length
Post by williamrouse »
If I have several lines or several paragraphs that are of line length 80 is there an automatic way to change the line length to a line length of 40 characters or to reverse the procedure from 40 to 80 characters?
mphare
Post by mphare »
Is soft line wrap on the slate?
It would sure be a nice feature.
