SCC Integration
ruben
SCC Integration
Post by ruben »
Hi all.
I knew about Zeus looking for a solution to integrate MS Visual Studio .NET and CVS. I've seen the Zeus SCC-SVS has been removed but it is still distributed with the Zeus Editor release (After installing the editor I can see I have this source control provider through the xScc utility).
The problem is I cannot make it work under MS Visual Studio 2k3. The error message I get is written in my home language but it says something like:
"Error initializing the source control provider Zeus SCC-CVS. It is not possible to use this provider to perform source control operations."
In addition, when I select that provider in xScc and click the Query button I get this message: "A non-specific failure has occurred."
None of the error messages is too much specific... :(
Did anyone make it work with MS VS .NET? Is it possible? Any suggestion?
I thought that SCC was a standrad...
Thank you very much.
I thought that SCC was a standard...
The Microsoft SCC interface is nothing more than an header file and a 5 page document. In theory it could work as a standard interface but in practice the interface is documented so vaguely it is quite difficult to correctly implement the standard SCC interface.
The Zeus SCC-CVS has only been tested against Zeus itself and will most probably not work with other SCC compliant IDE's.
If I remember correctly I recall seeing links to other SCC CVS modules on the CVS home page. These might be a better option.
PS: Here is a link that descrbes how to setup Zeus to use CVS: http://www.zeusedit.com/forum/viewtopic.php?t=237
