Paste Problem
webbsoft
Paste Problem
Post by webbsoft »
I'm having a minor problem and cannot figure out how to correct it.
Whenever I insert text that I have copied out of my program files, the paste does not insert in between my lines of code. It actually takes the existing lines and moves them out to the right of the line.
What I need it to do is move the existing lines down below the code that I have inserted.
Hope that makes since.
I think I understand what is going on. Zeus has several marking modes and correspondingly several cut, copy and paste modes. From what you describe it sounds like you are in column marking mode and what you need todo is use line or block marking modes.
For more information on the marking mode see the reply to the Can I perform Multiple Line or partial line Selection posting.
I hope this will resolve the problem, but if not, feel free to post some more details on how you are actually doing the text marking (ie user actions) within Zeus.
webbsoft
Post by webbsoft »
Thanks. That made it work just like I needed it to.
