A visual line wrap is good to have for knocking of the occasional note to someone. Having real CRLFs embedded is not real desireable because then when you copy the note into another application the CRLFs may not be where you wanted them, or you may not want them at all.
I am a current, happy user of Zeus. If Zeus had this feature then I don't think I would ever need to use notepad again.
Feature Request: Visual line wrap
Cool!
I'll keep my eye on the implemented feature list. Once I see the "folding line wrap", then I'll buy the upgrade. It would be great if it was implemented like notepad as a toggle on a menu, so you can easily turn it off an on, on the fly. In notepad, once you toggle it off or or, notepad just stupidly goes to the top of the form. You can do that, or have it return to the topleft character. Whichever is practical for you to implement, I will be happy with it. Typically, I am doing this with small files. But I could imagine someone toggling in a larger program to more easily edit some text output to the user. But I'll be happy either way.
I hate having to go into notepad for anything.
Love ZeusEdit! and your great support!
--Rick
--Rick
