For details on how to install and configure Ruff for Zeus go here: https://www.zeusedit.com/phpBB3/viewtopic.php?t=8407
With Ruff installed the following macro can be used to format a Python file inside of Zeus.
Using the Macro
To use this macro, save the code found below to the following Zeus file/folder location:
zScript\ruff_fmt.luaThis should result will be that the active Python file will be reformatted.ruff_fmt.lua
File Save Macro
The macro can be configured to be run automatically on the file save action. To do this use the Options, Document Types menu, edit the Python Document Type and in the Triggers section add the following changes:
File Save Postfix: $zud\zScript\ruff_fmt.lua
File Save As Postfix: $zud\zScript\ruff_fmt.luaJussi
-- Name: Ruff Reformatting Macro
-- Language: Lua Macro
-- Description: This macro will execute the ruff.exe utility to reformat
-- the current file.
local utils = require "utils"
-- details about the active document
local document, named, read_only, document_type = utils.document_details()
if (document_type ~= "Python Document Type") or (document == 0) or (named == 0) then
-- only complain if this is not a trigger
if is_trigger() == 0 then
message("This macro only works with named, writable Python documents.")
return 0
local dir = macro_tag("$fdd")
message("Python is formatting the code....")
local cmd_options = "format "
local cmd = "ruff.exe" .. " " .. cmd_options .. " " .. utils.checkLFN(file_name)
-- for debugging only
--message_box(1, cmd, "Command Line")
-- System Control Values
-- 1 - save the document before running the program
-- 2 - capture any standard output generated by the program
-- 4 - capture any standard error generated by the program
-- 8 - ask for additional arguments
-- 16 - the program will use the MS-DOS command interpreter (ie. dir *.* etc)
-- 32 - wait for the program to complete (the ESC key will cancel the wait)
-- 128 - capture output to a compiler window (not the default tool window)
-- Output Control Flags:
-- 0 - ALWAYS
-- 1 - NEVER
-- 2 - ERRORS
-- 3 - WARNINGS
-- 4 - ANYOUTPUT
-- display the tool window if any output is generated
local NEVER = 1
local ERRORS = 2
local ANYOUTPUT = 4
-- run with 'save', 'capture output' and 'wait' and 'compiler' options
local flags = 1+2+4+32+128
local caption = "Ruff fmt: " .. file_name
-- remember the current line count
local current_count = get_line_count()
if (system(cmd, dir, flags, caption, NEVER) == 0) then
-- reload the newly formatted docuemnt
FileReloadCurrent()
-- get the new line count
local line_change = get_line_count() - current_count
-- maintain the current line location
if line_change ~= 0 then
local line_current = get_line_pos() + line_change
-- check for an underflow of the line number
if line_current <= 0 then line_current = 1 end
-- maintain the current line postion
set_line_pos(line_current)
-- no errors detected
set_return_code(1)
-- some feedback
message("The formatting of the document is complete.")
message("The Python code in this file contains errors. Use the Window menu and refer to the Ruff fmt output for more details.")
beep();
-- formatting errors detected
set_return_code(0)
