Ollama LLM Fill in the Middle Code Completion
NOTE: The latest version of Zeus includes scripts that allow it to integrate with Gemini AI, OpenAI and Ollama.
These features can be found on the new Macros, AI menu shown below:
IMPORTANT: Before trying to use this macro, make sure you are running the most recent version of Zeus: https://www.zeusedit.com/download.html
Consider a Python file that contains the following text:
With the cursor on the line shown in the image, running the auto complete macro will result in this output response:
NOTE: Instructions on how to run these macros can be found in the header section of each macro script found in the Zeus zScript folder.
Legacy Macro
NOTE: The Ollama FIM macro shown below is now legacy as it has been superseded by the macros that come with the installer.
Here is the Ollama LLM Fill in the Middle Code Completion script that produces this code completion behaviour:
#        Name: Ollama Fill in the Middle Code Completion
#  Description: This macro will provide LLM Fill in the Middle code completion embedding the
#               result inside the document.
#  Setup:
#     1. Download and install ollama found here: https://ollama.com/download/windows
#     2. Form inside Zeus open a DOS command line prompt using the tools menu, and then
#        run the following commands.
#     3. Install the ollama Python package by running this command:
#            pip install ollama
#     4. Pick a model to be installed: https://ollama.com/library
#     5. Install the model:
#            ollama run codellama:7b-code
#     6. Make sure ollama server is running:
#            ollama serve
#  Usage:
#     To use, load the macro (i.e. F9 key), position the cursor and then run macro using
#     the Macro Execute (i.e. F8 key)
#     Alternatively use the Options, Editor Options menu and in the Keyboard section bind
#     the macro to the keyboard.
#  Example: Open a Python file inside Zeus and enter the following code int that document:
#               def remove_non_ascii(s: str) -> str:
#                   return result
#         Note: The '|' symbol in that code above represents the location of the cursor
#         Running the macro should then result in the following output being entered into
#         the file:
#                   """Remove non-ASCII characters from a string."""
#                   if s is None:
#                       return ''
#                   result = ''.join([i if ord(i) < 128 else '' for i in s])
#                   return result
import os
import re
import time
import zeus
import ollama
import asyncio
def atoi(str):
    resultant = 0
    for i in range(len(str)):
        resultant = resultant * 10 + (ord(str[i]) - ord('0'))
    return resultant
def ollama_generate(prompt, suffix):
    # set the library to used: https://ollama.com/library
    model='codellama:7b-code'
    # helps debugging
    #zeus.message_box(1, prompt, suffix)
    zeus.message('Starting ollama generate....')
    try:
        response = ollama.generate(model=model,
                                   prompt=prompt,
                                   suffix=suffix,
                                   options={
                                    'num_predict': 128,
                                    'temperature': 0,
                                    'top_p': 0.9,
                                    'stop': ['<EOT>'],
                                   stream=True
        # some sleep needed and clear the wait cursor
        zeus.yieldTask(100, 1)
        result = ""
        status = "Thinking (ESC to cancel)."
        message = status
        VK_ESCAPE = 27   # 0x1B scan code
        for chunk in response:
            result = result + chunk['response']
            # some sleep need and clear the wait cursor
            message = message + '.'
            if len(message) > 150:
                message = status
            if (zeus.key_down(VK_ESCAPE) == 1):
                zeus.message("Operation cancelled by user.")
                return False, '';
            zeus.message(message)
            #zeus.message(result)
        zeus.message('')
    except Exception as e:
        zeus.message("Failed to connect to ollama. Use 'ollama serve' to make sure the service is running.")
        zeus.beep()
    return True, result
def key_macro():
    # macro only works for documents
    document = zeus.is_document()
    # macro only works for read/write documents.
    locked = zeus.is_read_only()
    if (locked == 1) or (document == 0):
      zeus.message("This macro only works with named, writable documents.")
      zeus.beep()
      return 0
    window_id = zeus.get_window_id()
    line_current = zeus.get_line_pos()
    zeus.beep_disable()
    zeus.screen_update_disable()
    zeus.cursor_save()
    zeus.FunctionFindPrevious()
    line_start = zeus.get_line_pos()
    zeus.cursor_restore()
    if line_start == line_current:
        prefix = zeus.get_line_text(line_start)
    else:
        prefix = zeus.get_line_text(line_start, line_current - line_start)
        text_current = zeus.get_line_text(line_current)
        if len(text_current) == 0:
            tab_size = zeus.macro_tag('$TabSize')
            text_current = b' ' * atoi(tab_size.decode('utf8'))
        prefix = prefix + b'\n' + text_current
    zeus.cursor_save()
    zeus.FunctionFindNext()
    line_end = zeus.get_line_pos()
    zeus.screen_update_enable()
    zeus.screen_update()
    zeus.beep_enable()
    suffix = b'\n'
    if (line_end - line_current) > 0:
        suffix = suffix + zeus.get_line_text(line_current + 1, line_end - line_current + 1)
    else:
        suffix = suffix + zeus.get_line_text(line_current + 1, zeus.get_line_count() - line_current)
    suffix = suffix + b'\n'
    #zeus.message_box("line_current: " + str(line_current) + " line_start: " + str(line_start) + "\nprefix: '" + prefix.decode('utf8') + "'")
    #zeus.message_box("line_end: " + str(line_end) + "\nsuffix: '" + suffix.decode('utf8') + "'")
    if len(prefix) == 0:
        zeus.message('No prefix found. Place the cursor inside a function that needs to be completed.')
        zeus.beep()
    else:
        completed, response = ollama_generate(prefix.decode('utf8'), suffix.decode('utf8'))
        if completed == True:
            # makes sure we return the the original window
            zeus.window_activate(window_id)
            # insert the response
            zeus.line_append(response, 1)
key_macro() # run the macro
