Macro Exceute Tag - $MEX
The latest version of Zeus adds a $MEX macro tag which allows the creation of a tag value based on the results of a macro script.
This macro execute tag can be used in this basic format:
$MEX<macro_script>
Alternatively, the tag can be used in this arguments format:
$MEX<macro_script arguments>
The macro_script represents the name of the script to be run and the arguments represent space delimited argument values passed to the macro.
Here is an example of a typical script:
    local arguments = "";
    local count = argc();
    if count > 0 then
        count = count - 1;
        for i = 0, count, 1 do
            arguments = arguments .. argv(i)
            arguments = arguments .. ' '
    local message = "This output generated was by the 'mex-test.lua' macro."
    if (string.len(arguments) > 0) then
         message = message .. " Arguments Supplied: " .. arguments
    -- this will be the result of the macro expansion
    print(message)
This actual macro comes as part of the latest installation and can be found in the Zeus zScript folder in the mex-test.lua file.
Here is an example of how this macro script can be used using the basic format:
$MEX<mex-test.lua>
Here is an example of how this macro script can be used using the arguments format:
$MEX<mex-test.lua arg1 arg2 arg3>
To see how these work, use the Tools, DOS Command Line menu and run this echo command:
echo $MEX<mex-test.lua>
That will result in the following output:
And when this command is run:
echo $MEX<mex-test.lua arg1 arg2 arg3>
This output generated was by the 'mex-test.lua' macro. Arguments Supplied: arg1 arg2 arg3
Another example is the mex-dir.py macro, which lists the files in a folder based on file filter.
For example, this echo will list all text files in the current directory:
echo $MEX<mex-dir.py *.txt>
This echo example lists all text files in the c:\temp directory:
echo $MEX<mex-dir.py c:\temp\ *.txt>
sturt
Re: Macro Exceute Tag - $MEX
Post by sturt »
Thanks for that (may have replied to that in wrong thread).
