- Go to MSYS2 the home page and download and install the software as per the instructions found here: https://www.msys2.org/
- Once installed, open the shell using the following batch file found in the installation folder, or alternatively use the MSYS2, Windows Start menu to open the shell:
msys2_shell.cmd - As per the details found on the earlier link, it is now very easy to install the GNU C compiler using a command like this:
pacman -S mingw-w64-ucrt-x86_64-gcc - To install the complete set of development tools, use the toolchain package described here: https://packages.msys2.org/groups/mingw ... -toolchain
It can be installed using the following command:
pacman -S mingw-w64-ucrt-x86_64-toolchain - The non-ucrt version of this package is found here: https://packages.msys2.org/groups/mingw ... -toolchain
NOTE: The ucrt packages use the Universal CRT rather than the much older msvcrt.dll runtime.Code: Select all
pacman -S mingw-w64-x86_64-toolchain - In addition, as these commands are installing MinGW compilers, by searching for these artifacts and adding those folder locations to the system PATH means these compilers can also be run from the Windows command prompt:
gcc.exeCode: Select all
g++.exe - Finally, by using the MSYS2 command prompt you can use a suitable pacman command to upgrade these compilers as needed. Just refer to the MSYS2 site for more details.
Installing C/C++ GNU Compilers on Windows Using MSYS2
These are steps needed to install the GNU GCC and G++ compilers on Windows using MSYS2.
