Cppcheck - C/C++ Code Analysis Tool
Cppcheck is a tool for C/C++ code analysis: https://cppcheck.sourceforge.io/
To install the software, download and run the Windows 64-bit installer found on that page.
Thie installer requires admin rights as it installs to the following folder location:
C:\Program Files\Cppcheck
The installer does not add the installation folder to the system PATH so this will need to be done as a seperate user step as described here: viewtopic.php?t=6176
Cppcheck User Manual
The user manual for this tool can be found here: https://cppcheck.sourceforge.io/manual.pdf
Zeus Integration
To use cppcheck from inside Zeus, use the Options, Document Types menu to edit the C/C++ Document Type and inside the Tools panel add new tool using the details shown below:
Cppcheck '$f' File
cppcheck.exe
--platform=win64  "$fn"
$fdd
This will create a new C/C++ specific tool as shown below:
Testing the Cppcheck Tool
To test the newly created tool, save the following code to an example.cpp file:
int main()
  char a[10];
  a[10] = 0;
  return 0;
With that file open in Zeus the Tools menu will now show the cppcheck option in the menu as shown below:
Running that tool will then result in the following output, highlighting the error in the code:
Re: Cppcheck - C/C++ Code Analysis Tool
The cppcheck utitlity can be used to test projects and solutions using command lines that take those details as shown below:
cppcheck --project="foo.vcxproj"
cppcheck --project="bar.sln"
One issue this can cause is when the project code contains an #error directive, for example code similar to this:
// Release mode dynamic link multi-threaded dll C-runtime
#if !defined(_MT) || !defined(_DLL)
    #error The /MDd compiler switch is required.
#endif
Running cppcheck on that code can result in the following error:
The issue here is because those preprocessor values are not defined the #error is triggered and the cppcheck aborts any further checks.
To fix this the -D command line option can be used to define these preprocessor values as shown below:
cppcheck -D_DLL -D_MT --project="foo.vcxproj"
cppcheck -D_DLL -D_MT --project="bar.sln"
