Configure Zeus to Use jq to Pretty a Json File
1. Download the Windows version of the jq executable found here: https://stedolan.github.io/jq/download/
2. Copy that executable to this Zeus folder location (change the folder to match the user id):
C:\Users\<your user id>\AppData\Local\Programs\Zeus (x64)\zGNU\
Using jq to Pretty a Json File
Use the Options, Document Types menu and edit the JScript Document Type.
In the Tools Section add the following tool:
       Menu Text: jq Pretty: '$fn'
    Program Name: jq-win64.exe
       Arguments: . "$f"
  Work Directory: $fdd
    (o) Executable
    (o) Run hidden
    (o) Display on output
    [x] Capture stdout
    [x] Capture stderr
    [ ] Allow user input
    [x] Save current document before running
    [x] Add to popup menu
Using the New Tool
1. Open the following c:\temp\test.json test file:
{ "folders": [ { "name": "Project: Some Application", "path": "Application" }, { "name": "Project: Other Lib", "path": "Library" } ] }
2. With that file open in Zeus and as the active use the Tools menu to run the jq Validate tool.
3. This will result in the following output:
  "folders": [
      "path": "Library"
