Agent SVN: about the installation of a new license
michfranceschini
Post by michfranceschini »
I need to use the license of Agent SVN on different Powerbuilder versions on the same Window workstation: Powerbuilder 12.1 and Powerbuilder 2019 R3.
Do I need to buy two different licenses or I'm able to use the license on different Ide applications installed on the same workstation ?
Re: Agent SVN: about the installation of a new license
You only need one activation key for each user, so in this case you can use the same activation key for both versions of PowerBuilder since the user count still remains at one user.
